Old 06-06-2008, 09:34 PM   #2
boxster7614
My drivers side headlight started acting up on me. When I turned the fog lights on the blinker would not work and the headlight would sometimes dim and blink with the blinker. I removed the headlight and cleaned the electrical conectors where the headlight slides in and make contact with the car. This fixed the problem. Most likely you have some corrosion that is causing some resistance between conections. Possibly a bad ground...try cleaning the contacts.
boxster7614 is offline   Reply With Quote
