Originally Posted by pk2
Mike,
Mine doesn't really function correctly either. Checked all the switches and connections. Fine. Goes up and keeps 12v current flowing indefinitely till the ig. Is turned off,
I saw those relays in the wiring diagram. Did you try to take the motor aapart and clean the contacts?
Regards, PK
If you get a constant 12V one of the relays is malfunctioning and needs to be replaced - they're located in the rear relay panel behind the trunk lining.
