Originally Posted by renzop
If you are afraid of clutch wear there is one simple fix - don't use the clutch. That's right, I said, don't use the clutch. If you shift smoothly and slowly and put it back in gear at the exact rev-matched RPM you don't need a clutch.
Try it at low RPMs sometime. Pop it into neutral with your foot on the gas just a little. Then lot the RPMs drop for the next gear, rest your hand on the shifter and apply gentle pressure. It will drop right in.
Now, I do not recommend doing this as a regular habit. But doing it a few times will give you a better feel for how the drivetrain wants to shift. Then shift like that but with the clutch and you should get very long clutch life.
Regards,
Alan
Anyone doing this should be ready for some expensive tranny repairs.
1987 924S. 2002 996TT. PST-2
