there are two little cables that go from behind the back window to either side of the engine cover. these are the cables that you undo to flip the back window up and expose the motor hatch. are yours in tact? if one or more is broken or out of adjustment (they are adjustable), they won't pull down the back of the window enough and it will prevent the clamshell from closing all the way.
