Thread: warped rotor?
Old 04-26-2008, 08:50 AM   #13
insite
to answer the caliper rebuild stuff: when the inner seals go bad, they get soft. the inner seals actually retrac the pistons when you release the pedal. if they get soft, the pads don't retract and ride on the disks. this causes heat build-up and fade. i doubt if this is your problem. at any rate, if you want to rebuild the calipers, the dealers will NOT sell you the inner seals, only the outer dust boots. the best place to get seals AND dust boots is here:
http://www.zeckhausen.com/Brembo/Consumables.htm#Rebuild
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
