Old 04-17-2008, 08:41 PM   #10
clickman
I had to replace the plastic pull cord, and so I had to pull out the solenoid (actuator) to do it. I recommend you DO NOT remove the fender.
Here's an excellent DYI (which unfortunately wasn't available when I did mine):
http://www.renntech.org/forums/index.php?showtopic=13955
For the REALLY tight work of loosening the two screws holding the solenoid I used a small bit that comes with a multi-bit screwdriver and and a small boxend wrench that went over the back end of the bit. Be prepared with patience, it's a very tight spot. But it can be done - if I did it so can you!
clickman is online now   Reply With Quote
