Old 04-16-2008, 12:17 PM   #1
insite
Originally Posted by blinkwatt
Aren't people having an issue with the ends(where the bolts run threw) snapping under load?
the rod ends in the pic are high end three piece and won't break. they're rated to around 16,000lb radial load. the bolts would shear first.
you might be thinking of the brace that doesn't use rod ends, just holes drilled in a bar. in this case, any chassis twist could cause a torsional fracture. better to use rod ends. blink's design looks right on the money.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
