Old 04-01-2008, 03:38 PM   #5
beersnob
I recently had the canvas top from topsonline.com installed. I had an issue with the top not securing behind the plastic frame above the window when the top is put in the closed position. Make sure your installer understands this is a known issue for your top, made by Robbins.
After I noticed the issue I contacted Robbins and they were able to clue the installer into posible fixes ans it was taken care of.
Overall the top is great although I do have to crunch down a bit to see direct out the back window. As for the defroster as long as your intaller plugs it in and you have the switch you are good to go.
Jeff
beersnob is offline   Reply With Quote
