Thread: De-what?
Old 03-24-2008, 10:18 AM   #2
CJ_Boxster
Send a message via MSN to CJ_Boxster
Hey! Well De-ambering is the act or removing and replacing all amber colored lights and markers from the exterior of your car... For instance, Swaping out your half clear/half amber headlights for all clear 02+ headlights, also removing the half red/half amber taillights with 02+ taillights, then lastly there is removing the amber front bumper side markers and replacing them with 02+ clear/smoked markers.
Fuel Filter... You'll need a 10mm wrench or socket... socket is better.
Jack the car up, remove the center/tunnel cover held on by alot of 10mm plastic nuts and you will see the fuel filter. Remove loosen 10mm clamp, pinch hose ends and pull fuel hoses off the old filter and quickly slip yours in place before you end up with gas in your eyes.
Thats it in a nut shell.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
