Old 03-16-2008, 10:35 AM   #2
Tomikaze
Porschephile
Tomikaze's Avatar
Thank you for your answer. How about the rear rotors from a 986 S? Will those fit on a base 986?
Originally Posted by TriGem2k
Tom
The front rotors are a straight swap between the 986 & 987. I recently did this exact setup on my 2001.
The Rear however will not fit. The diameter on the hub of the rear 987 is too big to fit the 986.
I had a set of Zimmerman Cross drilled installed on the rear to match. If you do get the zimmerman rear rotors make sure to paint the hat to match the OEM 987 front.
2004 Porsche Boxster S
Portland, Maine
Tomikaze is offline   Reply With Quote
