Old 03-11-2008, 09:25 PM   #10
blackbox
Wink door/interior lights are a main symptom
Glad to be of help. When I had this problem, it drove me crazy. so I know how you feel.
You mentioned your interior lights coming on. This is another big symptom of the door latch mechanism going bad. Mine started coming on randomly and then they were on all the time. Even after I would lock my car with the remote, the lights at the bottom of the door would stay on for a long time. After the door latches were replaced, the lights now go out instantly.
I would try replacing the latch on the side that's giving you window problems. If that doesn't fix it, I would take it into the stealership. You mentioned that you still had warranty on your car. If you've got warranty, use it as much as you can.
blackbox is offline   Reply With Quote
