Thread: water leak
Old 03-11-2008, 12:50 PM   #1
c4s
There are small plastic hoses that run from the front/top of the front trunk. The hoses are about the size of a drip system hose and can either disconnect or clog causing the water in your front passenger side... same can happen for the driver side.
The hoses are supposed to allow the water to flow from your windshield to the base of the car. Porsche has diagrams (I think you can find them on line) to show locations... I tore down the carpet on the passenger side of my 05 and found a disconnected hose... fixed same. The hose was just behind the glove box...
Pull out the carpet and begin to drip water down the windshield then look for the leak... good luck.
c4s is offline   Reply With Quote
