Automatic Window Lowering
I can post the solution when I determine what is wrong. I read on the PCA forum that this problem can be caused by loose connectors where the wiring enters the door. I took a look during lunch today, but it is running through some rubber seals. Didn't have any tools with me to pop the rubber seals and take a look in there. I am also going to call Auto Atlanta where I bought the microswitch to see if they have any other ideas. When I ordered the switch, I seem to recall them saying that if the switch doesn't fix the problem, then it is the window regulator (evidently an expensive part).
