gary -
just realized your first post mentioned you really liked the low look of your car. if that's the case, you want the H&R. i don't have the measurements handy, but they lower the car quite a bit. if boxs2000's car is 24-7/8 with the eibach pro, you'd be at your current ride height with the H&R.
the H&R are a little stiffer than the M030, but not much. i would go with the bilstein sport struts since they're supposedly valved a little stiffer than the M030; this will balance out the stiffer springs. don't even consider sway bars other than M030 for what you're looking to do.
