Old 02-15-2008, 09:22 PM   #10
Euphoria
Euphoria's Avatar
Send a message via ICQ to Euphoria
Originally Posted by gcb
Good luck...
I have a '03 Boxster S that had the same problem "multilple" times! The dealer was nice enough to try to fix it "multiple" times also. Cable detached once, cable stretched out another time, not even sure of the excuse the other times.. but they did say it was a issue with a lot of the boxsters. Its much better know.. but not nearly as tight and uniform as original (or as I feel it should be).
Thanks for the feed back GCB... Did the detached/stretched cable cause the headliner on your Boxster to sag? I need to know if the two issues are related. Cause if they are, that means my dealer has somehow caused the cable to break and as a result i have a saggy headliner.
If that is the case then my dealer is in trouble cause I already filed a complaint against him with Porsche Middle East and they are currently investigating the matter.
Euphoria is offline   Reply With Quote
