Originally Posted by boxs2000
Make sure when you disconnect the battery that you wait a few minutes to let the remaining juice(power) in the car drain also make sure you touch a metal part of the car like the door jamb or ignition switch that way if you have any static electricity on you it discharges and you don't set off the airbag when you go to disconnect it. Out of curiosity, does the MOMO set up you are doing have an airbag? If not won't your airbag light stay lit?
no there is no air bag.
ill just take the bulb out, i really don't care too much about that
