Old 02-09-2005, 11:27 AM   #7
QporscheQ
QporscheQ's Avatar
Sure thing. I guess I would mask off everything but the area on the inside of the new rings, then hit it with a layer of the spray. Then remove the mask. Make sure you read the instructions if you use the 77. You actually need to let it set for a bit after you spray it and before you try to stick it to something. Also, if you have kids or a dog or something, make sure you keep it out of reach, as it can dangerous.
There are various tacks, like I think 75 is more like post-it note stuff, and there is a 90 that is very very sticky.
Word of Caution: This is a spray, so it will go everywhere when you spray it, anything it touches will become sticky!!! Be careful. Also, before you start, shake the can until your hand goes numb, then switch hands and shake it some more.
Q
QporscheQ is offline   Reply With Quote
