Originally Posted by dcporsche99
Hey Victory,
The emblem on the steering wheel is usually stuck on via 3M backing. Hopefully, this is true for yours too. I personally like the steering wheel without the emblem so I removed mine shortly after I purchased the car. I was able to remove it just by using dental floss---lift one of the corners just enough to fit the floss behind it and slowly drag it down with a side to side motion. There was some sticky residue left, but I just used soap and water to get it off. Good luck!
Spyder, nice pics!
I believe the later models 2000 and up that use the 3 spoke steering wheel are embedded and not stuck on with adhesive like the earlier 4 spoke wheels are. If you remove it completely it will show a indentation.
