It is always coolant that appears out of the front radiator. I think it is too much of a coincidence that large amounts of water collect on the ground from the location of the radiator, and the coolant warning light coming on indicating a low level of coolant. There are no other leaks from anywhere else in the car.
If you fill the coolant tank and leave the car there are no leaks and the coolant level remains the same. It is only when the car is run that the leaking starts. I checked in after a short blast and the radiator was soaking wet, all the internal area around it was also damp.
I am getting a new one fitted on Tuesday so hopefully the problem will be solved.
