Originally Posted by HB.
What tool did you use for the grinding? My brackets are not fitting correctly either, the middle hole is not clearing the small screw.
Used a Dremel with a grinding wheel. Not a whole lot as I posted but enough to get a good fit. Also rounded the sharp edge on the bottom of the plate. I did NOT drill any of the fitting holes larger.
Since installing the braces I have added the M030 Sport sway bars and the handling is dramatically improved. No other changes other than Vertex braces fore & aft and the sway bars. Little or no weight transfer in corners observed from behind the wheel. Ordered them from Sunset in Portland Oregon including bushings for $235.00. Most bang for your upgrade book in my estimate.
AKL
