Originally Posted by OldBlevins
I've been working to correct a paint problem that's only visible when the light is reflected at just the right angle. I've stripped the wax, claybarred the car, and am using Menzerna Intensive Polish with my Griots Orbital polisher (orange cutting pad).
It has helped a little, but the spots are not coming out. I believe the previous owner may have let the car get rained on without any wax and these are water spots, but I'm not certain. I can keep polishing and hope I don't go through to the primer (arg), accept it, or try another approach. Any suggestions?
Manzerna IP is a moderately agressive polish. I would certainly consider a more agressive polish and pad combo (and more time on the Orbital on a higher speed) prior to wet sanding.
I am not familiar with the Griots buffer -- can I assume its a multi-speed device that you are running on high enough speed?
Good luck. Let us know how it comes out.
