Old 10-17-2007, 10:38 AM   #7
Burg Boxster
Originally Posted by TVC15
yes, sorry, it's a 2005, 987.
According to the service log, they will perform the following:
brake flush
battery service
oil change
bg fuel induction
coolant flush
bg climate vent service
fuel injector service
In that case, I'd just have them do the O&F and brake flush (should be done every 2 if you don't do any AX or DE events). Everything else on that list is pretty much bogus.
-Just check the (distilled) water level in your battery.
- personally, I'd run a bottle of techron (for fuel injector/etc.) thru the tank before you have them change the O&F.
- Coolant is "lifetime", but I'd be inclined to change at 5 years or 60K. add distilled water if you need some
They'll still stamp your book for the O&F and brake flush which should then run around $500. At least that's what I'd do.
