Originally Posted by efahl
Blink, you're probably doing the braking test wrong if you think that's the case. The test is as follows: start at 20 mph, accelerate to 130 at full throttle, then threshold brake down to 20 again. Repeat 20-30 times, and only on the last one measure the distance from 130 down to zero.  It's not a matter of doing it once, but how many time you can do it where the big brakes give you the advantage.
Eric
agreed! on the track, the base boxster brakes are really lacking. the 's' brakes are night and day here.
