Thread: Who would win?
Old 08-11-2007, 01:02 PM   #16
blinkwatt
Send a message via AIM to blinkwatt
Originally Posted by Boxtaboy
Actually, the secondary cat bypass pipes that Fabspeed sells replaces the set of cats that are connected to the muffler (which the 97-99 models also has), so in theory, you could probably also install them, but then you wouldn't be running with ANY cats on the car anymore, and so that would be illegal. The 00+ models still have a set of precats that are connected to the headers, so you still technically have cats if you install the fabspeed bypass pipes on the 00+ models.
The manifold - 2nd catpipe(1st on a non e-gas) mounting points differ from the non e-gas to e-gas so I don't think the 2nd cat bypass pipes would fit on a non e-gas anyway. The opposite end that connects to the 'u' pipe should fit though(since the mufflers are interchangeable from 97-04.5').
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
