				Originally posted by QporscheQ
Lux, is there something like this that is waterproof or specifically for automotive uses?  The things I do similar to this (appliqué installation) usually remain inside and live in a much friendlier environment than the front of a car.
3M has a variety of PSA (pressure sensitive adhesive) that should meet your needs.  They range from the very low tack (e.g. Post-It notes) to fastener replacement strength (e.g. mounting spoilers on cars, etc.).  A PSA that I use a lot is 3M's VHB (very high bond).  It's essentially permanent once it cures.  If you go to 3M's website, there's a bunch of product spec sheets that you can look at.  You can also call them up and speak with an applications engineer that can guide you to the correct product for your application.
