Old 12-19-2004, 07:42 PM   #3
QporscheQ
QporscheQ's Avatar
If your adhesive is gone, look into using something like 3M Spray-77 or its big brother Spray-90. 3M claims it is transparent. The 77 is similar to the post-it note stuff but in a spray form and more tacky. The 90 is similar only much more tacky. I'm not too sure how this stuff handles water, I've seen it loose tack when wet on occasion.
Lux, is there something like this that is waterproof or specifically for automotive uses? The things I do similar to this (appliqué installation) usually remain inside and live in a much friendlier environment than the front of a car.
If nothing else Spray-77 is one of those million and one household uses things. It is just about as useful as duck tape. If you have a can at home you'll find yourself using it for all sorts of stuff. I believe there is also a cheap Elmer’s Glue knock off that is not as toxic and less tacky.
Q
QporscheQ is offline   Reply With Quote
