Old 07-25-2007, 12:09 PM   #2
insite
Originally Posted by jbboxsters
On my 02 Boxster S with lowered suspension the rear tires (and maybe the front but to a far less degree) have the camber off enough that it is visible from the rear of the car that the inside of the tires are going to wear much more than the outside. The tire store told me there is no camber adjustment and the only correction was to raise the car back up. Does that sound correct? The reason the car was at the tire store was because the rear tires were completely worn down on the inside edge only. I just purchased the car and was told it was lowered by a very reputable customizer.
this is very common. the problem is that our rear toe changes significantly as we modify camber. when you lower the car, proper camber settings would make the car pidgeon toed. the correction is to purchase a set of toe steer arms from either Tarrett Engineering or The Racer's Group. i think there is a slightly used set on rennlist right now for $300.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
