Old 07-03-2007, 10:53 AM   #3
insite
Originally Posted by John V
Then tighten the toe adjusters and use the camber adjustment cams to dial the toe back to zero. This will give you minimum negative camber and zero toe.
i'm in the same boat as these guys; my car is lowered (RoW M030). the least camber i can run at zero toe is -2.25 degrees. for those looking for a solution, the TRG or Tarrett Engineering toe links will correct this problem. unfortunately, they are $500 a set.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
