Originally Posted by poopoopaul
Currently, my clutch is toast, as is my flywheel, apparently. So now I'm considering changing to the Unorthodox Racing flywheel. Any recommendations or yea/nays? I use my 2001 986S as a weekend car and heavy DE car. I'm replacing the clutch with a OEM Sachs clutch. Is this reasonable or ridiculous. Please help. Also, any companies that carry these parts cheapest would also help too.
if you go with a lightweight single mass flywheel, you shouldn't use an OEM disk if you plan to drive your car on the street. the OEM disks are solid centered; they rely on the spring loaded dual mass flywheel for cushion.
you can use the stock Sachs pressure plate, but get a spring centered disk from Vertex Auto.
