Old 06-06-2007, 10:37 PM   #3
MNBoxster
Hi,
Not a problem. I had my Boxster on Jackstands for more than 2 weeks as I removed, painted and reinstalled the Calipers, installed new Pads, flushed the Brake Fluid, drained the Tiptronic, replaced the Filter, Gasket, Fluid, and cleaned the Radiators (in-between living Life).
No ill effects whatever. Just make sure you have the car as level (and consequently an equal amount of weight on each Jackstand) as possible.
If longer, I would Saran Wrap the Shock Piston Shafts to protect them from Dirt, Debris, and Corrosion as a portion of them is not normally exposed and could damage the seals when re-inserted. If lifted for an extended period, I might also support the struts to keep from stressing the Bushings in areas thay normally are not. Hope this helps...
Happy Motoring!... Jim'99
