Screws help on the wheel wells, but the wider tape is to keep the skirt adhered to the convex curvature of the car's body, which is not mirrored on these skirts. You must flex the fiberglass in place just below the door handle area of the car and push it in about 3/4 of an inch to make contact with the car's body.
I had to remove one side and clean it up, then re-apply it with thicker tape to get it to fully adhere to the side of the car and hold. Now the other side is pulling away and I must do it as well.
I just wanted to give anyone buying the gtmotorsport.net skirts a heads up on this issue.
