I only use the Dremel while the curved plate is outside the car. I trim about a 1/16" to 1/8" where the curved plate binds against the shock tower. I do not trim anything on the car itself. I will try to get a pic of what I am doing. Otherwise the installation should not be troublesome. I don't even have to release the cables on the top to fold the window up out of the way. Again I will try to get a pic for you. Once the plates are bolted in place I plan on fixing the bar into both of them. I will post progress pros and cons.
AKL
