Having scratched my head for a few hours a month ao about this one here's the info. (its sooooo easy when you know how !!)
1. Remove the small carpetted corner section behind each seat - there's a small screw located about 3 inches up in the carpet pile itself, and a hex nut at the top against the roll bar
2. put the hood fully down, remove the blanking plugs and fit the spinlock sleeves (these are handed and labelled as such, and have a locating notch to make it foolproof). Tap fully down with small piece of wood.
3. Put hood fully up.
4. Carefully pull back the hood lining behind the side window glass. You will be able to see the side of the spinlock, with the receptacle for the bolt facing you. Place the securing nut and your 5mm allen key into a plastic sandwich bag (so if you loose connection the bolt doesn't disappear inside the panel), with the bolt threads sticking out of the corner of the bag.
5. LOcate the bolt and tighten til about 80% in, then pull off the bag and continue to fully tighten in a normal fashion
