Old 09-02-2021, 11:13 AM   #1
986 Boxster's Avatar
You're welcome esc. Thanks, you're car looks very nice also, I love the wheels. I have Koni Special Active and H&R sport springs. For spacers I have 20mm rear and 25mm front, I had 20mm at the front but I didn't like how it looked so I changed them to 25mm. You would have to measure for spacers, your wheels could be wider than mine and your off sets also might be different. Over the years I've had all kinds of suspension set ups on my cars, currently I have B12's on my 330xi, which is basically Bilstein B8's with Eibach Pro springs (similar to what you have on your S4) and although the car handles really nice, it's not as smooth of a ride as the Konis with the H&R sport springs. The Koni Special Active are designed to go with lowering springs up to 1.5 inches drop, they are soft while cruising but they stiffen up when you need them to. Do a bit of research on them and you will see for yourself that they are very good struts for the money. Overall I am very happy with my suspension set up, the car handles like it's on rails, without sacrificing the ride quality to much. I just hope that they last. Your car looks just as low as mine, I don't think your ROW struts are not designed to go with the H&R sport springs, your struts could be wrecked by now, just for the fact that you been running them with the H&R sport springs.
986 Boxster is offline   Reply With Quote
HTML code is Off
