Old 07-02-2018, 08:35 AM   #1
Porsche 986 wide, low and rebuild for myself.
100mm+ wider with spacers
Porsche 911 turbo wheels.
315 and 235 tyres
Bilstein killer coilovers.
Chassi rebuild to fit big tyres.
Supercharged with Eaton Blower.
+ Piggy fuel injection.
Rebuild exhaust with Gemballa muffler.
10.1 touchscreen stereo with full engine control.
New plastic around the car.
Real Defusers in back.
Gt2 hybrid front.
No stickers or racing stripes,, i skip that.
More to come this summer:
Methanol /water injection and big a-s-s front brake discs.
Gocart in a boxster yepp
Drive and enjoy or kill the road with full trottle.
Robbe986 is offline   Reply With Quote
Old 07-02-2018, 08:57 AM   #2
More
Old 07-02-2018, 09:25 AM   #3
redciv1's Avatar
Looks quite interesting, Probably need to take that for a test drive for more accurate assessment!!! What are the front flares as I cannot figure I which one's they are.
redciv1 is offline   Reply With Quote
Old 07-02-2018, 09:41 AM   #4
It is japan bunny fenders.
Testdrive :-)
U will be amazeed, totally control in corners.
Old 07-02-2018, 09:46 AM   #5
[QUOTE=Robbe986;574274
Old 07-02-2018, 09:54 AM   #6
Looks great with the body kit. Very wide and aggressive. Do you know what the horsepower numbers are?
X
ShortRound is offline   Reply With Quote
Old 07-02-2018, 10:24 AM   #7
redciv1's Avatar
Testdrive :-)
Rocket Bunny fenders? Customized from another car if so which one?
Old 07-02-2018, 10:39 AM   #8
Yepp bench 300hp on wheels today and runs smooth.
330-350hp on wheels with meth and 0.2 bar more boost.
A porsche 911 turbo overrun me a couple days ago at a strait road,but later in curves my boxster was a lot faster even with friends in car.
Maby the driver in 911 turbo was a chicken but a boxster is totally awesome in corners.
Old 07-02-2018, 10:50 AM   #9
Yes rocket bunny fenders for Nissan, i really dont remember model.
Look at ebay if interested.
Nothing fits from box so have to massage the plastic.
My boxster is not a original with stripes and stickers.
Every part nead a mecanics, good luck if u like the style of my car.
Old 07-02-2018, 10:54 AM   #10
Great looking set-up!....
Almost as I would do it!....
Very interested in the methanol/water Injection,do you have any information on this system?, I have a TPC supercharger in my 98.
As luck would have it,I also have a 10" andorid stereo, in my other toy, 2011 jk Wrangler. I thought about getting one for the 986 but decided to keep it stock for now.
Great looking toy!.....
Sent from my MHA-L29 using Tapatalk
gonzzo is offline   Reply With Quote
Old 07-02-2018, 11:04 AM   #11
Tpc = Eaton M62
It will work fantastic.
TPC boxster kit Boost 0.5-0.6 bar to keep the heat and engine safe.
U can with meth/ water run more boost if u want or keep the same boost.
Anyway it will be a upgrade for your box
Old 07-02-2018, 04:30 PM   #12
Robbe986, you don't happen to have pictures of the methanol injection system installed, do you?....
I think the best place to mount the tank and pump would be in the trunk, right next to the 7th injector module....
Do you have a 7th injector in your TPC kit?, or did you get the Unichip piggy back instead?....
Great thread!.....
Old 07-02-2018, 09:56 PM   #13
Cunningr's Avatar
TPC Turbo kit is $7500, and the methonol injection $1500. Wonder how it affects relabillity.
Old 07-03-2018, 12:19 AM   #14
I have never build a turbo boxster so i dont know
But in general:
Boxster engines is ****************quality from the factory.
So the relabillity is not good from the start.
TPC kit is ok
Old 07-03-2018, 12:35 AM   #15
Nope i dont
Meth system cost 400-500 dollar for my setup.
I Have a extra piggyfuel ECUMASTER at home so i probably build my own kit.
And only buy the nossle/injector
I think so too.
A frend of mine used to work at saab as engineer and they did some major tests on turbo engines with water injection
He told me that the best place for the meth/water injector is with the same spot as extra fuel injectors.
7th injector
Great thread!.....[/QUOTE]
Thanks !
Old 07-03-2018, 01:47 AM   #16
Old 07-03-2018, 04:12 AM   #17
Christian H's Avatar
Hi Robbe,
Car's looking great! Something a bit different well done fella
Christian H is offline   Reply With Quote
Old 07-03-2018, 06:24 AM   #18
Originally Posted by Christian H View Post
Hi Robbe,
Thanks man !
Old 07-03-2018, 07:10 AM   #19
Dual posts
Old 07-03-2018, 07:23 AM   #20
Have ordered:
AEM V2:methanol/water Nozzle Kit, 100 dollars
A copy of Bosch 044 fuelpump 87psi 50 dollars
Mounting kit 15dollar
Fuelcell 20L 114 dollar
Will use a headlight relay for the fuelpump, 20amps
And probably a air-pressure contact/module i already have 0-1.5 bar to power up the relay,
HTML code is Off
