Old 10-10-2025, 07:20 AM   #1
Clutch Sticking To Floor
The other day when I engaged the clutch in my 5sp 2002 Boxster, the clutch remained floored and would not shift gears. I am not a mechanic, but attempting a self diagnosis and guessing it might be my slave cylinder. I do not have an owner's manual for this vehicle and googling conflicting information and hoping I can get some answers in here....
1) On a 2002 Boxster, does the clutch fluid and brake fluid share the same reservoir?
2) If not, where is the clutch fluid added???
samg1965 is offline   Reply With Quote
Old 10-10-2025, 09:09 AM   #2
Yes, they share the same reservoir.
Old 10-10-2025, 11:42 AM   #3
Good possibility is that your clutch has air in it. Try bleeding the clutch system. If that is the reason, the 'fix' is almost no-cost to sort out (unlessa somethign is really wrong that caused the air in to the clutch system...).
2001 996 C2 Manual
Old 10-12-2025, 11:39 AM   #4
I was thinking so. O'Reilly told me they were different systems with unique fluid.
Old 10-14-2025, 11:45 AM   #5
Motive Power Bleeder
Sam, you mentioned that you are not a mechanic, but bleeding the brakes (and clutch), is not a difficult task, as long as you can put the car on jackstands to remove the four wheels.
I would suggest you to buy a Motive Power Bleeder, is not expensive and very easy to use, there are many videos showing the bleeding process, good luck!
Old 11-09-2025, 02:20 PM   #6
Yes, the clutch and brakes share the same fluid reservoir in the front trunk near the windshield. Check the fluid level and top it off with DOT 4 brake fluid if it’s low. If the clutch still sticks, the slave or master cylinder may be failing and could need replacement or bleeding.
Pringle86 is offline   Reply With Quote
Old 01-06-2026, 02:05 PM   #7
This was happening to my 2001 Boxster S with the 6 speed and I believe it was related to some cracked fingers in my pressure plate. It stopped happening after I replaced the clutch and pressure plate.
ahowelltech is offline   Reply With Quote
