Old 10-10-2025, 07:20 AM   #1
Clutch Sticking To Floor
The other day when I engaged the clutch in my 5sp 2002 Boxster, the clutch remained floored and would not shift gears. I am not a mechanic, but attempting a self diagnosis and guessing it might be my slave cylinder. I do not have an owner's manual for this vehicle and googling conflicting information and hoping I can get some answers in here....
1) On a 2002 Boxster, does the clutch fluid and brake fluid share the same reservoir?
2) If not, where is the clutch fluid added???
samg1965 is offline   Reply With Quote
Old 10-10-2025, 09:09 AM   #2
Yes, they share the same reservoir.
Old 10-10-2025, 11:42 AM   #3
Good possibility is that your clutch has air in it. Try bleeding the clutch system. If that is the reason, the 'fix' is almost no-cost to sort out (unlessa somethign is really wrong that caused the air in to the clutch system...).
2001 996 C2 Manual
Old 10-12-2025, 11:39 AM   #4
I was thinking so. O'Reilly told me they were different systems with unique fluid.
Old 10-14-2025, 11:45 AM   #5
Motive Power Bleeder
Sam, you mentioned that you are not a mechanic, but bleeding the brakes (and clutch), is not a difficult task, as long as you can put the car on jackstands to remove the four wheels.
I would suggest you to buy a Motive Power Bleeder, is not expensive and very easy to use, there are many videos showing the bleeding process, good luck!
Old 11-09-2025, 02:20 PM   #6
Yes, the clutch and brakes share the same fluid reservoir in the front trunk near the windshield. Check the fluid level and top it off with DOT 4 brake fluid if it’s low. If the clutch still sticks, the slave or master cylinder may be failing and could need replacement or bleeding.
Pringle86 is offline   Reply With Quote
