Old 08-10-2024, 04:19 AM   #1
O2 weird situation
Hello, can someone please help me with a weird situation regarding an o2 sensor that is acting very strange
So, the story is this, about an year ago I bought a 986 from 99. Love the car but i had stored in the ecu an error: o2 ahead of cat bank 1 no signal. No check engine on the dash.
I proceeded to change the sensor with a brand new Bosch part. After installing the part i now get the error: 02 Sensor Ahead Of Cat. Conv., Cylinder (1-3) below limit value
No leaks on the exhaust, the check engine is off but i don t get it why the ecu shows this error, specially the o2 is new.
Could this be related to the fact that i have a Dansk Motorsport exhaust?
Thank you
Alexchris11 is offline   Reply With Quote
Old 08-10-2024, 07:12 AM   #2
More likely a wiring harness issue.
Old 08-10-2024, 07:16 AM   #3
Sorry, just edited the first post. The error i got now is 02 Sensor Ahead Of Cat. Conv., Cylinder (1-3) below limit value
To give more details about this situation, when I finished mounting the new sensor, I started the car and I check with my scanner the values of the new o2. The values were great, 0.2 -0,7.
Then after 10 minutes of driving, I checked again and the values are with minus (-0.1 - -0.3).
Old 08-10-2024, 08:58 AM   #4
What code numbers are you seeing?
Old 08-10-2024, 09:57 AM   #5
02 Sensor Ahead Of Cat. Conv., Cylinder (1-3) below limit value, I do not have a code, my scanner shows only this error.
Old 08-10-2024, 10:42 AM   #6
Without the actual codes, I cannot help you any further..................
Old 08-10-2024, 01:12 PM   #7
I think is p0133
Old 08-10-2024, 02:43 PM   #8
P0133 is the aging out of the sensor ahead of the three way cat on bank #1.
Old 08-10-2024, 06:39 PM   #9
Again sorry, today i diagnosed the car with a different scanner. The error code is:
P1115 - Oxygen Sensor heating side 1 ahead of Cat - below lower threshold
Old 08-11-2024, 04:54 AM   #10
Registered Member
Back to JFP’s original comment - sounds like wiring problems.
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
Old 08-11-2024, 07:53 AM   #11
P1115:
Heating current too low
-Interruption in heater circuit
-Interruption in sensor wires
-Short circuit
