Old 05-12-2024, 05:48 PM   #1
elgyqc's Avatar
Scoring on the camshaft bearings
I found some scoring on the camshaft bearings that are beside the chain on bank 2 of my 2000 2.7 engine. All other bearings are perfect. The engine runs well.
I am replacing the cam chain tensioner pads and a couple of other things.
I am hoping this is not a major problem and that I can put it back together as is.
Grant
elgyqc is offline   Reply With Quote
Old 05-16-2024, 09:04 AM   #2
I dont know much about metal ware, But at 87 K does not seem bad..?
flmont is offline   Reply With Quote
Old 05-17-2024, 07:55 AM   #3
elgyqc's Avatar
What worries me is the bearing surface in the head, the last photo in the initial post. The other surfaces are smother and shinier.
These are the bearing caps (that are the top half of the bearing that I worry about... they look good.
and these surfaces at the other end of the camshaft are smooth and shiny.
Maybe I am panicking for nothing, but it is the first time I have noticed this on the four engines I have disassembled to this point.
Grant
Old 05-17-2024, 10:21 PM   #4
That's not an issue. And you can't fix it anyways, unless you replace the head.
Old 05-21-2024, 05:04 PM   #5
elgyqc's Avatar
Thanks Homeoboxter, your opinion carries a certain weight with me. So you figure I should just reassemble it and not worry. I realise that the alternative is to replace the head which I evidently really do not want to do.
Grant
Old 05-23-2024, 10:54 AM   #6
I've seen worse, this is not an issue IMHO. There's a lot more to worry about in this engine
