Old 11-06-2023, 08:02 AM   #1
Another Hard Starting Question
Hello,.I trust that 20 PSI of cranking fuel pressure 0n a 02' boxster 2.7 is NOT enough to start it,..I researched the form and I found where it's suppose to be 3.3 Bar,..which i think is to equal 30-35 PSI,it was hard to start 2-3 times last week./and now will not start at all, but really tries to,It sputters and pop's a lot then it just crank's, Thank's ,for the help...Frank
Old 11-06-2023, 08:16 AM   #2
You have a fuel pressure issue.
Old 11-06-2023, 09:16 AM   #3
PSI times 14.504 equals bar...... so 3.3 bar would be 47.86 psi
Old 11-08-2023, 07:13 AM   #4
Thanks for the Info Gentlemen, fuel pump on the way..! Frank
Old 11-08-2023, 01:35 PM   #5
Doesn't these cars have a fuel pressure regulator? Just curious..
Old 11-08-2023, 01:37 PM   #6
Early cars did, it was on the fuel rail, later models, it is in the fuel tank.
Old 11-08-2023, 06:21 PM   #7
Thanks JFP!
Old 11-23-2023, 12:53 PM   #8
Installed fuel pump,Great pressure now..but still a no start..so crank sensor next after that...who know's , hopefully crank sensor is it ! Happy Thanksgiving !!
Old 11-24-2023, 05:16 PM   #9
Installed crank sensor..back to cruising
