Old 06-16-2021, 10:08 AM   #1
embryoguy@mac.com's Avatar
Red temp light
Guys, driving and I start smelling and seeing white smoke come passenger side vent. The red light on temp gauge starts flashing but temp remains at 180. I saw some water drips as I on driveway as I pulled in. It’s parked.. waiting to check coolant level. Thoughts? Thank you!
embryoguy@mac.com is offline   Reply With Quote
Old 06-16-2021, 10:37 AM   #2
Well you have an issue with the coolant system.
Start with a visual inspection.
Then do a coolant system pressure test with a coolant system pressure tester.
Harbour freight has them for around $90.00 they will test any coolant system including the coolant tank cap.
Old 06-16-2021, 01:45 PM   #3
So my coolant seems to be empty at least from the reservoir in the trunk. Should I try buying porsche coolant and adding it back in to see if its ok?
What was odd was that even though the red light started flashing on the temp gauge, the temp didnt go above 180.
Old 06-16-2021, 01:57 PM   #4
edc
550 Anniversary
edc's Avatar
You have a coolant leak. Adding new coolant is like pouring it into a sieve. You have to identify the cause you haven fixed the problem.
Old 06-16-2021, 03:39 PM   #5
As blue said, fill with distilled water and then pressure test the system. Find and fix the leak before you drive it. It may have not overheated this time, but it will... And aluminum blocks don't tolerate that.
Old 06-16-2021, 07:33 PM   #6
So discovered leak coming directly underneath the engine. So it seems it’s the water pump. Going to have the water pump and thermostat replaced.
Old 06-17-2021, 05:31 AM   #7
1998 Boxster Silver/Red
That would be a good time to inspect/replace the motor mount.
1998 Porsche Boxster
