08-21-2020, 06:36 PM
Door lock problem
Until yesterday everything was fine. While driving I hit the door lock button on the dash (which I almost never use) and since then my key fob won’t lock/unlock/open trunks, and when I use the key to unlock the door, the alarm goes off till I put it in the ignition. This happened to me once before but I can’t remember how I solved it. Anyone have any idea what to do? 03 base
09-04-2020, 01:39 PM
I have exactly the same problem have you found the solution.
Regards
09-04-2020, 02:09 PM
Regards
Sadly, I have not. I tried replacing the battery in my fob, but as expected that did nothing. I even stopped by the local dealer, who said they hadn't encountered this problem before so didn't have a top of the head solution, and wanted me to check it in for full diagnostics and evaluation, which I had neither the time nor money to do. So, I'm just living with it for the moment, hoping someone will come up with an answer for me/us.
09-07-2020, 02:17 PM
Always a good idea to state the year and model of your car when asking for advice. I don't have an answer but I suggest you read the owner's manual on the locking system... along with the alarm, it is a bit complicated. The owner's manual can be found online.
Grant
09-07-2020, 03:19 PM
I said 03 base in OP. I might suggest that you read a post through to the end before replying, and if you have nothing helpful to say, don’t bother.
09-07-2020, 06:09 PM
Hmm, a bit touchy... sorry I missed the final 2 numbers and four letters.
Grant
09-07-2020, 06:26 PM
Who's askin'?
And there goes Samson, making friends again. ;-)
Welcome to the forum. And for whatever it's worth; I think the best advice on this really IS to go take a look at the owner's manual and what it has to say about the central locking system.
04-05-2021, 01:36 PM
Hi, i was thinking if you have found the solution already, I tried checking the cable continuity between the connection in the door hinge and alarm under the seat without success, any news?
Enviado desde mi SM-A505G mediante Tapatalk
2001 Boxster S
