Old 04-17-2020, 03:08 AM   #1
geraintthomas's Avatar
Lightbulb Valved idea for Oettle exhausts - 3D diagram included
[Deleted.]
Porsche Boxster S Type 986
Bi-xenon Headlight Upgrade | 987 S 18" Anthracite Alloys | Android Head Unit | 5000k 55w HID's | 5000k Cree DRL's | 5000k Cree number plate lights | Cree LED Indicators | One-touch roof operation | Bypass exhaust pipes | Parking sensors | Ambient footwell lighting
geraintthomas is offline   Reply With Quote
Old 04-17-2020, 04:59 AM   #2
[Deleted.]
Old 04-17-2020, 05:11 AM   #3
[Deleted.]
Old 04-17-2020, 06:02 AM   #4
[Deleted.]
Old 04-17-2020, 07:35 AM   #5
Okay, forget my previous posts. I've got a new idea below:
(Size is off completely, just for illustration purposes.)
It consists of a waterproof solenoid valve:
A BSP threaded barrel nipple cut in half for the two ends
And some thick clamps for the joins
All to go on this section of my bypass:
Nice and simple. I'll probably fashion a heat shield for the solenoid itself, but should be okay. Any issues anyone can see? Can't see why this wouldn't work.
Also, apologies for the deleted posts - if an admin could remove them, that would be grand.
Old 04-17-2020, 08:28 PM   #6
Is the solenoid heat resistant?
Old 04-18-2020, 02:00 AM   #7
Up to 100 degrees, so need to measure temps. The metal is fine, and I can't imagine that area of the bumper would reach 100, nor the pipes themselves as they're just bypasses.
Going to go for a drive soon and will measure it.
Old 04-18-2020, 03:16 AM   #8
Newbie
Cool idea!
I've seen someone use a turbo wastegate as an exhaust valve in this same manner. On a Volvo of all things.
Sent from my SM-G965U using Tapatalk
1998 Porsche Boxster Base - 2005 Volvo S60R AWD - 2003 Subaru Wrx Wagon - 2003 Jeep Wrangler Rubicon - 1992 Subaru Loyale Wagon w/4in Lift - 2004 Dodge Ram 2500
GLImages is offline   Reply With Quote
Old 04-21-2020, 01:34 AM   #9
Just measured temps after a run to the shops and back, 315 degrees. I've scrapped the idea unfortunately.
The exhaust is booked in when lockdown is over to get some seals welded, so I'll ask him about plumbing in pipes similar to the original PSE, but after the 2" vacuum valves, I'll ask him to reduce to 1". I like the sound as is and wouldn't want to change it, plus it'll be a tight fit for the facelift bumper.
Old 04-21-2020, 03:13 AM   #10
They make 2" and bigger electric exhaust dumps and manual cable control ones.
You could block off the dump part.
ADOR is offline   Reply With Quote
Tags
idea
