05-04-2019, 12:29 PM
Shorter flywheel bolts for lightweight flywheel
I just tried to install a used light light flywheel and noticed that the factory bolts are too long. Does anyone know where to buy shorter ones? I can’t seem to find them.
Cheers,
Stu
2003 911 C2
NASA HPDE Instructor
05-04-2019, 02:44 PM
Who's askin'?
McMasterCarr.com
05-04-2019, 03:59 PM
my favorite store (So.Cal) for awkward and hard to find metric hardware is McFaden-Dale I found them a couple of decades ago when looking for uncommon size bolts
for the Fiats and Alfas..
05-04-2019, 04:53 PM
m10x40. just measured mine.
05-05-2019, 05:56 AM
Awesome! You all rock.
2003 911 C2
05-05-2019, 07:23 AM
Racer Boy
Yes, we all do rock!
05-05-2019, 03:07 PM
Cheers,
Stu
I would cut the new factory bolts.
05-05-2019, 08:49 PM
dremel... ? :-)
05-06-2019, 04:47 AM
We have a Fastenal down here, if you have one close by you can take in the old bolt. They have a good selection of metric.
05-06-2019, 10:11 AM
1998 Boxster Silver/Red
Originally Posted by Gilles
dremel... ? :-)
Yup. Dremel it off (measure twice, cut once) and feather the end. You should be good to go!
1998 Porsche Boxster
05-06-2019, 01:28 PM
dremel... ? :-)
Thin cutoff wheel, when you buy the bolts make sure to get the same grade as the stock bolts & buy a couple nuts to fit the bolts. Thread a nut onto the bolt before you shorten the bolt, & then removing the nut restores the threads as you remove it.
05-06-2019, 03:03 PM
You can’t cut them unfortunately the shoulder is too long. I found some replacement 8.8s at Home Depot.
2003 911 C2
