Old 01-13-2018, 01:36 PM   #1
Rich
torque specs for veriocam and caps
What is the correct torque for the cam shaft caps and the veriocam on 2000 boxster s? Is it 10FT lbs?
Rich XTR is offline   Reply With Quote
Old 01-13-2018, 02:07 PM   #2
For the cam covers it's 10 ft #, there's a specific order that with a little looking you can find on one of the Pelican do it yourself online articles. As for the variocam, are you asking about the solenoid? I replaced one of mine yesterday tightened it to snug and then took it another 90 degrees.
2001 Boxster
2007 Toyota Highlander
Old 01-13-2018, 02:21 PM   #3
Rich
yes the solenoid and cam shaft caps. I tightened them to 10 ft lbs and one of the cap bolts stretched and almost broke.
Old 01-22-2018, 03:45 PM   #4
Rich
I was able to get the torque spec from a dealer and they both are 10nm or 7.4 ft lbs for anyone else that does this job.
Old 01-22-2018, 10:42 PM   #5
Oh, ouch. 2.5 Ft lbs doesn't sound like much, but that's significantly over torqued for those little bolts.
Old 01-23-2018, 06:12 AM   #6
Rich
I lucked out. Only cost me $3.50 and a little time. Could have been much worse.
