Old 08-05-2017, 10:24 AM   #1
Durametric Litronic Faults
My car has OEM Litronics. 03S. Using Durametric I can move them center/up/down
The headlights come on and go to hi beams
Durametric comes up with the following faults (the actual fault numbers are 1,2,3,4,5,6)
1. Engine Path Left
2. Engine Path Right
3. Axle Position Sensor – Front
4. Axle Position Sensor – Rear
5. 5v Supply Axle Position Sensors
6. Control Unit Coding Error
Is there something I should do?
Bob
Old 08-05-2017, 12:32 PM   #2
1. Engine Path Left
Bob
You have just about every Lit code possible, but the big one is the last one: Control unit coding error. This means that the DME cannot communicate with the Lit control module. I would look for a wiring problem or loose connection first, it that is not it, you may need either a new module or get the old one recoded, which requires a PIWIS.
Old 08-05-2017, 12:35 PM   #3
Thanks...I will check it out then.
Old 08-05-2017, 01:51 PM   #4
So..I found a plug that was disconnected from the right side light...plugged it back in and ran Durametric.
Error 5 & 6 are gone but 1.2.3.4 are still active.
Anything ele I can (should) do?
Thanks again
Bob
Old 08-06-2017, 12:03 PM   #5
Looking a little further I found the bracket that holds the little lever on the suspension broken. I have ordered it (actually 2 in case the rear is also damaged) so I hope that wraps up my Litronics adventure.
Old 07-31-2024, 12:02 PM   #6
Litronics
Can you update on your troubleshooting & fix of the HBA fault codes
gwinterhalter is offline   Reply With Quote
