Old 02-08-2018, 12:51 PM   #21
I am having the same exact problem as the OP. I am going to try to angle the car forward and refill. Only thing that scares me is the "engine oil pressure too low" warning. Any advice as to why that happens when changing coolant?
Arctic987 is offline   Reply With Quote
Old 02-08-2018, 01:49 PM   #22
seningen's Avatar
Dumb question -- but is there any chance coolant was added to the oil by mistake?
Drain the oil, or at least pull the oil filter and look to see if there is intermix.
If it overheated at all -- there is a freeze plug in the heads which if that goes -- instant intermix.
Mike
mike@lonestarrpm.com
Old 02-08-2018, 03:09 PM   #23
AZ986S's Avatar
When adding coolant, you may want to use a coolant vacuum refill tool... like this one.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 02-08-2018, 10:31 PM   #24
Getting a coolant system as long and snaky as the boxster's burped well is a real PITA. I have to admit to throwing in the towel and letting my local dealer do my coolant refill and burp for this very reason. In the Bentley manual there is a very specific procedure to doing the burping, and I believe it is in Wayne's 101 Projects book as well. Sounds like you are getting it sorted, just be careful and keep an eye on it.
Old 02-09-2018, 08:52 AM   #25
2003 S, Arctic Silver, M6
paulofto's Avatar
+1 ...... I bought a similar unit for about $60 CDN when I replaced my left side radiator due to a small leak. Refill was simple using the vacuum system and I had zero issues.
Old 02-09-2018, 01:59 PM   #26
Might just need to get me one of those! Always a good reason to buy a new tool, right?
