Old 01-31-2017, 10:15 AM   #1
Most lead-acid 12v batteries are made by Johnson Controls or Deka IIRC. Not much difference in the battery performance.Only difference is the branding.
http://www.consumerreports.org/cro/news/2013/04/beware-the-best-and-worst-replacement-car-batteries-can-be-from-the-same-brand/index.htm
Select on correct spec,warranty,price. Lots of anecdotes in Search but it is like oil choice......
If you re in a cold climate a larger CCA # may be an advantage but otherwise minimize the weight with smaller choice from the correct spec range. Get the correct terminal placement !
Old 01-31-2017, 11:41 AM   #2
Thank you!
zealous is offline   Reply With Quote
Old 01-31-2017, 12:58 PM   #3
If you want to spend a few extra bucks go for Interstate
__________________________
'58 356A coupe, just a driver
'00 Boxster S fair weather - daily driver
'11 Jeep Grand Cherokee Limited - winter daily driver
'92 F250 - junk hauler; previous Porsches '95 993;'08 Cayman S;'70 911E
356Guy is offline   Reply With Quote
