Old 10-24-2016, 10:51 AM   #8
if you turn ignition on, do you hear the fuel pump?
Did the car run fine after you started it with the battery power from another car or was that the time when the problem starts?
Did you check all fuses?
Did you put the car on a diagnostic tester and read the DTCs?
Regards, Markus
Hi Markus
No sound from the fuel pump.
I checked all the fuses relating to fuel pump, ecu etc. All ok.
When it first refused to start, I was 1 mile from home. It started no problem.
Got it home, tried it again and nothing, even with another car battery on on it.
Lanark is offline   Reply With Quote
