Old 06-26-2016, 12:11 PM   #1
Inner tie rod removal
Is it possible to rremove the inner tie rod end using a 30 mm crows foot or is the special tool necessary. Pelican says to use a pipe wrench but it doesnt look lkke theres much room in there to use a pipe wrench.
Thanks.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 06-26-2016, 01:10 PM   #2
There really is no room for much of anything when working on the inner tie rod end. We use a Mayhew tool that slides over the tie rod and grips the inner flats, and it pops them loose with no fuss:
Old 06-26-2016, 04:58 PM   #3
Thanks JFP. Autozone rents a generic tool. Im going to see if it works.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 01-09-2017, 09:36 PM   #4
Need to counterhold the rack portion?
[QUOTE=JFP in PA;501083]There really is no room for much of anything when working on the inner tie rod end. We use a Mayhew tool that slides over the tie rod and grips the inner flats, and it pops them loose with no fuss:
Revived! Just before purchasing Mayhew tool.
JFP. Could I ask? Do you usually ​counterhold the rack portion in any way on removing and torqueing the inner tie rod in?
And If so, the rack holding device, like Huzar's tool: Hercula Grip, are on the market
(Products to suspension - Huzar EN).
Are there any other safer effective methods for the counter holding?
bachmoza is offline   Reply With Quote
Old 01-12-2017, 04:54 AM   #5
kk2002s's Avatar
I bought the harbor freight inner tie rod tool around $40, it was not metric but had adapter so close it works and I figured I may never use this again. There was no need to grip the rack with that tool. Should be all just gripping the inner tie rod to remove and install
Seal Grey
Old 01-12-2017, 05:49 AM   #6
So, I understand that 1-1/4" crowfoot adapter of your tool worked. That is very helpful. Thanks.
And...
Counter-hold at sensitive steering rack or not,I believe, is another safety- pursuing step unrelated with whether the tool can or not to release and install the inner tie rod to the rack.
Old 01-12-2017, 08:32 AM   #7
[QUOTE=bachmoza;522170]
Again, counter holding is not required, we have never had an issue doing it this way.
Old 01-12-2017, 10:14 AM   #8
More here:
http://986forum.com/forums/performance-technical-chat/64940-need-counter-hold-steering-rack-inner-tie-rod-job.html
